- Build Rating
- 5.00 star(s)
I heard this was a good boost, and I’m in a boost phase.
This is my first JHS build. I’ve never even tried a JHS pedal before this. You could also say it’s my first Dumble pedal build. There’s no difference between the two from what I know. I actually have the notadumble fumble, but it stays mint in the box along with the unopened notaklon.
This silkscreen had borders for larger caps, so I waited until my next Digikey order. It’s a very easy build. The bias procedure is as simple as it gets.
Here’s the short version. I love the way this sounds with single coils. It adds an upper and mid top-end clarity while still having that single coil characteristic. On humbuckers, I don’t have a use for it.
Like the Arche Boost, and @HamishR ’s Epic Boost, it’s a two knobber that has a control to increase the amount of bass (called INPUT here).
I like it. It’s worth trying if you’re not exclusively a humbucker player.
