Fun with CMOS - part 1 - The CMOS Raincoat
Good question. It's not straightforward to calculate. LTSpice is fairly accurate with transistor stages like the Raincoat, but the CMOS gain stages are difficult to calculate or simulate accurately because the behavior in the linear mode is not specified in the datasheet or controlled in manufacturing. I have LTSpice models of generic CMOS inverters, but because the actual devices vary so much, the simulations are not particularly accurate.
The previous stage has a non-zero output impedance, so that is in effect the input resistor of the next stage. By the same token, the input impedance of a CMOS inverter with feedback is low, so without an input resistor it loads the output of the previous stage. These impedances are non-linear and frequency-dependent, which further complicates matters. CMOS gain stages running in linear mode are capable of a max gain around 10x to 20x, so that influences the overall gain and freq response as well. The behavior is also influenced by the rail voltage. I've found that there is a sweet spot between 4V and 5V where the gain is highest. What I'm getting at is this: our best move is to breadboard and test the circuit.
I have a couple 4049ube chips I bought to play around with that I need to throw on a breadboard. Might finally tackle it tomorrow because I'm still fiddling with some distortion circuit on the "spare" breadboard.
My recommendations:
Keep it simple. Start with just two inverters. Adjust the rail voltage.
CD4049s manufactured by Texas Instruments are noisy. They're fine when used as digital parts, but not so good as analog parts. For reasons unknown to me, the CD4007s manufactured by Texas Instruments are quiet. That's why I prefer to design circuits with CD4007 over CD4049. I have some vintage CD4049s from Hitachi, National, Signetics and RCA that are quiet, but they are hard to find.
I once aimed a shot at an inverter overdrive. I used N.O.S. Motorola MC14049UB, which are very quiet.
I used the output stage of the Fat Sandwich WH-301, which wires the unused inverters in parallel for even lower noise, with a front end like above. Indeed, there is no perceivable noise.
Note that this measure inflates the current consumption astronomically.
According to an internet demo of The Raincoat, its tone apprears similar to the aforementioned unit. It has the typical coloration a MOSFET imparts. Not bad, but it behaves far from any dynamics associated with an overdriven tube amp. If you push it hard, it sounds ugly to my ears.
I do not care about this pedal, although the optics grew very appealing.
It's a Big Muff, it's supposed to sound ugly. :ROFLMAO:
(It also has no MOSFETs)
The Muff doesn't, but the inverters do. To my ears a discrete MOSFET stage like has the same "something" in its tone. Something dark.
I agree, Muffs can sound ugly - and they generally do to my ears. Unless you noodle along with some Gilmour-ish chords, then they work.
BTW, the inverter drive "barks", but it sound better if masked by a subsequent beautifier of sorts.
Ahh, I was assuming you were referring to the original Raincoat circuit (since you mentioned a video), which is all BJTs.
Is there a video demo of this CMOS version somewhere? I kinda wanna hear it but I'm too lazy to breadboard it. :ROFLMAO:
I'm too lazy to breadboard it again. My impression was the Raincoat sounded way better, which is why I abandoned the CMOS "Raincoat."
"Experiments that failed too many times..." BÖC
... managing the gain and bandwidth of each stage.
Ah, the ole' interstage attenuation. The heart and soul of all tube amps.
Yes, this would probably need to be revisited. But truly, I don´t expect sonic miracles out of the technology.
Your self-knitted push-pull approach is remarkable though.
Ahh, I was assuming you were referring to the original Raincoat circuit (since you mentioned a video), which is all BJTs.:ROFLMAO:
... which I was indeed. I thought Chuck's version was just an improved version. But incidentally, the demo I heard sounded dark, and I thought I heard the ole MOSFET. So much for perceiption...
AFAIK, the only company producing new CD4000-series ICs is Texas Instruments. Their recipe is noisy when the CD4049 is operated in linear mode. If you can find old RCA or National Semi parts, they are quiet. Strangely enough, the CD4007s made by TI are quiet. That's why I prefer to design with those. The only advantage of the CD4049 (or CD4069) over the CD4007 is the CD4007 only contains three inverters. The 4049 & 4069 contain six. If and when we find a circuit we really like, the smart thing to do is design it with a CD4007. In the case of the circuit above, it would be easy enough to replace the first stage with a BJT or opamp. For the time being, this is just me playing around.
I know this is a really, really old post - but did you ever discover any other series of CMOS chips that are quiet? I'm pushing my luck for room on this build that can only fit a DIP16 in there, and needs a couple more stages than just 3.
Care to share a schematic?
your best bet is to find something that was NOT made by TI. These will be "vintage" parts since everyone except TI quit making CD4xxx series parts before the turn of the century. you can try Amazon & eBay, but caveat emptor. I would not even bother with AliExpress, too much counterfeit stuff there.
It's basically just the two halves of a Animato split into controllable sections (as part of me messing around with dual PCBs) with some slight changes - I've got a Sziklai pair of BD139/140s that is controllable between a mid and treble boost upfront, and a cut down 22/7 at the back. I've individually made each of these and they sound great staged as the original and even going Muff first sounds pretty good to my ears.
I've sort of designed these around a fairly universal control/PCB layout that I've used for a couple of other pedals, so I'm a bit more limited on space than I would be otherwise.
I have not. Wasn't aware that MC14xxx parts were still in production. I'm curious too.
Looks like they're only available as SMD. I don't mind building boards with SMD ICs, but they suck for breadboarding.
