Fuzz Factory
xconverge
This build tested my sanity in every possible way. "It's only a few resistors and a few capacitors, how bad could it be". I am happy with the outcome but this build was insanely time consuming and issue prone for how simple of a circuit it is :LOL:
First time using germanium anything, Got 4 GT402 from stompboxparts and they all tested pretty good (using the RG keen method) with low leakage, using a 77/115 hfe pair for Q2/Q3. I have an order from oleg (SOVCOM on ebay) on the way with some other goodies so I might try some other combinations (or more likely just breadboard another fuzz face or tone bender to play with them).
First time doing etching....My printer isn't really up to snuff, I did a few test pieces of aluminum to dial in the process but struggled a lot here, I think primarily due to my printer. It says it is 600 DPI but I am pretty sure it is only doing 300 DPI, and all of the advanced settings did not get me there, however I used a few months-worth of toner in testing it, so that's cool. The mask would leave some tiny pinholes that then would be very difficult to completely mask off. I am using NaOH, which you can't just touch up the mask with some nail polish, perhaps ferric acid and using sharpie/nail polish to touch up the mask would be the way to go for me, but all of that is still a bandaid on a subpar printed toner mask.
Originally I wanted to use the alpha 9mm pots like @owlexifry in https://forum.pedalpcb.com/threads/vero-zvex-fuzz-factory-w-oc71-mp20.30371/ and that sabro layout, but stompboxparts was out of the values I needed so I decided "how bad could it be" to just use regular solder lug pots.
The answer is below (cover your eyes):
I breadboarded it, liked it, then moved it to vero. Everything that could go wrong, then did go wrong.
1. Burnt/destroyed 2 pots (the stab pot), probably due to a combination of the following issues
2. A few specks of bridged connections on the vero that were a huge pain to find
3. The clear coat got on to where the jacks mount, so the enclosure was floating at like ~4.5V at times, took awhile to find because clear on an enclosure is less obvious than powder coating preventing a good ground
4. Another intermittent ground wire because of how many times I took it in/out of the enclosure
5. I didn't realize 1 spot of the protoboard underside was touching an un-taped millimeter of enclosure which caused another short
O well, I am happy with the outcome and it was fun I suppose. I can get some pretty creative sounds out of it and some completely unhinged oscillations and generally unusable sounds.
Etching was it's own set of challenges. I finally got a result I liked after 2 attempt/give up/sand flat tries:
Then I went to spray some clearcoat on it, and the solvent ate away all of the paint. I didn't want to paint it again/sand it again because the etch was now becoming VERY shallow, so I tried this product (a special crayon essentially)
I was very hopeful this would be what I needed. So I applied it to one of my test etchings, waited a few minutes, and then went to wipe the excess and it just like took all of it off. So I repeated the test but waited an hour, same result. So I decided to just crayon it and then let it sit overnight... I could not wipe ANY of it off (filled or non filled portions)...oof, give me a break please.
So I painted it 1 more time, sanded it SUPER carefully with 400 grit, and ended up with my final result (the finished picture with the knobs). I then (stupidly, but it worked out) used the same clear coat, but started with 2 or 3 of the FAINTEST coats to minimize the solvent interaction on the black paint. Then 1 or 2 thicker coats and we were done.
I could probably adjust the design or reverse etch and get good results even with my printer, but I don't mind dymo labels or paying tayda to UV print the enclosure.... I also would get a pretty similar result just doing a toner transfer and clear coating it, but then I wouldn't get to play with chemicals.
No longer on vero! Took a fraction of the time to put back together due to the board mounted pots 🙏
Swapped the germanium transistors because I have more now. No longer receives talk radio like the previous build with all of the long wires, so thats maybe a downside :LOL:
6x boards from JLCPCB took a little over a week to arrive for $6 shipped! Money well spent.
That’s awesome. I don’t necessarily enjoy intense debugging and fighting my own self sabotage, but it is very satisfying and rewarding when a problem is solved. I like it when stuff just works, but I do get a little extra joy when I had to struggle a bit.
Knocked out a second one for a friend today since they just had a baby and I had the parts on hand already. Used shielded wire for the input jack->3pdt and didn't use a 3pdt breakout but other than that, basically the same. I don't have a set of 5 (smallish) knobs lying around so it gets some mixed up colors, I dig it though.
Q2 P416B hFE 114
Q3 P416B hFE 73
I chose (forgot) to clean up some of the pitting with acetone before clear coating it, so its a little bit relic-ed
Next time I will probably stick to toner transfer of the design + clear coat. I definitely am getting better at the etch process, but I am able to get ALL of the toner off the transfer paper, and am still left with pitting, so the printer just wont cut it as a good mask. I am going to give it 1 more shot with a reverse etch, since the pitting wont matter as much in that case
Thanks for posting the trials of the build, it helps us. Cool build
Here is the final update on my original failure protoboard since it was torn out in case I got the motivation to figure out where I messed up...
Couldn't find any bridges, checked all of the resistors, checked all of the capaci....
RIP
I put a 10nF instead of a 100nF for C2
Makes sense, it basically neutered the low end going into the following transistor stages. It sounded more like an overdrive than an aggressive fuzz. I probably could have detected/read/DMM this on the board in-circuit, but I get why I missed it (with all of the other problems this build was giving me) and am not annoyed at myself :LOL: I did breadboard this before building it, but I kept the breadboard version alongside it (correctly populated) instead of plucking components directly from it, so I just grabbed the wrong bag for the part!
