PCB Mania's Fuzz War Overlord boost section not working right.
I get considerable volume drop and increased distortion after C13. On the input side the signal is normal, but on the out put of C13 it has this problem. I replaced C13, and severed the connection to the board on the output side, the signal went clean. I jumped it to the transistor side of R24 (I have had to fix a number of PCB mania's pedals this way) and the issue came back.
I don't understand enough about transistors to know if the issue could down stream of 2n5088. My thinking is if I see the signal change at C13 then its an issue with every thing between the output side of C13 and the base of 2n5088.
