Like, a SAG or BIAS control?
It's hard to say for sure, but it doesn't look like both stages are starved.
Is lug 1 going to ground or is it just a series resistance? I don't see any spokes to the ground plane but that doesn't mean they aren't there.
You can always add your own starve circuit of choice to just about any fuzz (save digital).
Do any PPCB fuzzes have voltage control ala mythos hephaestus.
here’s the problem I have with a global voltage starve control:
It changes the bias for all transistors. Especially for a two transistor circuit, that means slight changes to the global voltage will have big changes to the local Q2 voltage in addition to the changes the global voltage has on Q2.
Voltage Sag/Bias control is super overrated in my opinion. Everything is happening at the extremes so a bias switch is a better option.
But that means I already have several pedals that do that and I won't have to make any new pedals. What a buzz kill.... or should I say fuzz kill...
I guess the question is- does the Hephaestus just have a straight-up transistor bias knob or an overall starve? If it’s the former (which sounds likely), I’m not sure how the Mythos is getting quite that much lower octave. I certainly get it on a Fuzzly Bear clone, but it‘s not quite as strong… Maybe the Mythos has a transistor bias knob with a different pot value than would normally be used for that..? If not, I don’t see how the Hephaestus is any different than the other “Bosstones With Bias” in that regard. Here’s the pic I posted in the other thread:
What does that entail? I have an Executive Fuzz to build and wanted to add the Heph’s volts control. It sounds like the advice in my original thread may be a transistor bias mod. I’m still new at this, please excuse my lack of knowledge. Would love some guidance!It’s clear as day they are simply varying the source voltage.
