Fuzzy Fox help
Jiberjew
Hey all. I’m having a fun time with this build, first off. Second; on the top left and top right, there are a couple spots labeled GE. I’m certain one side needs to be a silicon diode and the other germanium diodes. And if so, is there a value better than the other that I should use for either? Third, which side is for the silicon and which side is for the germanium??? I’ve heard great things about this build, so I can’t wait to check it out! (Excuse the sloppy build, and thanks for the help!)
If you use an on/off/on, you'll get no clipping in the center, I believe.
Note, there will be a large volume difference between no clipping and the Ge.
I like to team the GEs up in series with 1N400x. It takes the threshold higher and preserves the characteristics of the GEs.
