Hello, I'm back on it, finally.
I built the circuit of the Malachite / G2 stock and I like it. It's a nice overdrive.
I have some parts on socket so I made those experiments to get a clean preamp.
I replaced R8 22k with a 10k. The effect is considerable: this makes a noticeable volume and high frequency loss, and I don't lose too much distortion. Leaving out the LED I get just a bit of volume boost.
Leaving out C7 10nF and C14 1nF it's not enough to avoid all the treble cut. The same about C5 47pF.
I didn't change the 1M Gain pot just because I can't set at min value to test the sound, and even low setting cut a bit of volume.
What I get after all these mods is a dirty sound at half gain setting and a clean sound at min gain setting, but it's a bit muddy and the volume loss is still too much.
I increased the volume replacing R23 15k with a 4.7k.
Anyway, there is another problem about the volume loss. Increasing the volume thanks to R23 or just through the Volume pot I realized that the background noise is rise up. Indeed, with the toggle switch set at center, the softer mode where we have a drop of volume I notice, indeed less volume, but the noise is the same.
Paradoxically, I got more noise with this new clean sound than with the stock overdrive sound, because the volume is lower, but not the noise.
I'd like to keep to argue about the possible mod of this circuit, even if I don't want to mess up too much the board. Maybe I'll do next time with a new board.
I didn't touch the first stage, maybe I can boost a bit without get more distortion.
I didn't socket C8 1nF, but maybe I could take off this, too, to rise up some treble.
How much can help decrease the ceramic caps 120pF?
