jessemhopkins
I'm going to preface this by saying I know I should post pics and I know I should go through with my DMM and test values, but just asking in case any insight can be offered short of that.
I'm having a time with this Kliche. At the lowest gain settings, it sounds nice and adds a good boost to my signal, but as I increase the gain pot it's actually cutting both volume and high end. I put sockets in so I could test out different diodes so I initially assumed that was the culprit, but it's exactly the same regardless of what diodes I put in place, or even if I remove them completely (I don't even hear any popping or added noise if I remove them while the pedal is engaged). I even replaced the sockets JIC. It leads me to believe that I maybe have a value wrong somewhere else on the board or a bad component and I'm looking for suggestions on where to check based on the issue described.
Any thoughts?
Any thoughts?
