Likez2Jam
Welp fellas. The noobie made his first real f*** up today. I read somewhere that if you're putting in diodes you should use a socket, because the heat could damage them. Well the particular diodes (1N4001 Rectifier diode) going into my first kliche drive build didn't fit inside the sockets(now I know, test the socket before soldering). So I got them out by heating and solder sucking my mistake out. NOW I can't get the left over solder out of the hole to put the components in.
so 2 questions:
1. How to get the leftover solder out (my solder sucker is not working. Do I need a better one? A specific solder tip?)
2. Can I put fat lead (leed, not lead...well maybe...?) Diodes straight to the board once the first issue is resolved?
so 2 questions:
