hey all, i’m in the process of building a multi-effect box with 3 circuits within, the ep booster from taydda, glory hole and oasis from pedalpcb.
i’m at the stage right before boxing up where im testing how the circuits sound and i’m trying to figure out where i want the ep booster and order switch. anyways, the oasis works perfectly but the glory hole only bypasses the signal and makes no noise when engaged. i think all my joints are okay so i’m guessing it’s having to do with putting the glory hole and ep boost on the same positive power jack lug? i’m not sure, please help me out if you can see the problem! thanks
