noahjbauch
Hey, guys! Pretty new to this. This is my 4th or 5th project, so there are a lot of things about my wiring that I KNOW are janky (for instance, the switch is wired instead of soldered right into the PCB because I didn't drill the hole in the right spot on my enclosure), so please bear with me.
The bypass signal works fine, but when the effect is engaged, it just creates a lot of fuzzy noise. No signal from my guitar gets through at all. However, the volume and gain pots do turn the noise up and down and the tone pot affects the tone of the noise exactly how I'd expect it too.
I read through some older posts about this circuit and tested a few of the IC and transistor pins with my DMM, and I haven't found a value that doesn't pretty closely match what it seems like it should based on people have said in the past. If anyone has any ideas, I'd love some help! Thanks!
