Glue Factory Od part list
K Pedals
Anybody have a part list or maybe a picture of the board so I can see what components I need?¿
It's Just Another Tube Screamer. According to this site, it's based on the ProTone Dead Horse (aptly named) Overdrive. I pulled the Dead Horse schematic (attached) from the web, this should give a clue what will be on the parts list. IC is not identified, but since the Tube Screamer uses diodes and not the opamp to create distortion & clipping, pretty much any low-noise opamp will work. You're looking for a dual opamp in an 8-pin DIP package such as TL072, NE5532, JRC4558, LM833, OPA2134, etc. Before you build this one, you might want to check out all of the other TS clones available on PedalPCB.
Awesome!!!
Thanks!!!
That schematic has an error or two.
Here's the BOM:
R1 1M
R2 1K
R3 510K
R4 10K
R5 10K
R6 10K
R7 220R
R8 1K
R9 1K
R10 1K
R11 1K
R12 510K
R13 10K
R14 100R
R15 10K
R16 10K
R17 10K
R18 4K7
R19 10K
C1 27n
C2 1u
C3 51p
C4 220n
C5 220n
C6 220n
C7 1u
C8 100n
C9 10u
C10 47u
C11 47u
C12 100n
D1 1N4148
D2 1N4148
D4 1N5817
IC1 JRC4558
Q1 2N3904
Q2 2N3904
DRIVE A1M
TONE B5K
VOLUME B100K
Oh duh! That 51 Ohm resistor is really a 51pF cap.
Where does the 2nd 47uF cap go?
I always question using a linear taper pot for volume. Unless you're using the top half of the volume control, audio taper is the way to go.
The schematic I had used a 47uF for the main filter cap instead of 100uF. Now I can't find the dang thing.....
