snotrockits
Moving this thread to Troubleshoot from another thread. Hopefully to fix the issue I'm having but also catalog for if anyone else that experiences the same issues.
This was a similar topic, but never saw a follow up to see if the users issues were resolved.
https://forum.pedalpcb.com/threads/griffin-ricochet-surfy-bear-clone-issues.21658/
Wondering if I can pick anyones brain on what might be wrong.
Just Built a Griffin Ricochet with the improved mixer.
Only getting dry signal that is a little fuzzy.
Dwell and Tone arent doing anything. Wet mix does nothing. The only thing working is dry mix.
Absolutely no reverb. Even when crashing the tank. (Using a brand new SurfyPan Extra 4AB3C1B)
The MOSFET's (or at least the heat sink I have installed on them) is getting CRAZY hot.
TP1 is measuring 5.65v. R15 has a 1.5ohm resistor.
If anyone has any tips or has ran into this before, any advice would be super welcome.
Thanks!
Some things that have been asked already:
No sound when crashing the tank means return stage isn't working. Only further idea is a checklist;
Thanks!
- Verify the tank send/return are the right way around and isolated from enclosure. REV IN on the board connects to IN on the tank . Can be confusing.
Verified correctly connected - Did you pre-test your FETs?
Not very well I think. Ordering new ones and will being doing a more thorough job on round 2. I see posts that this can be rather critical - Verify wiring at the footswitch and jacks. Verify any sockets are fully seated.
Verified correct - The mosfets are rated for something like 175C. They run too hot for a touch test. Having 5.65V for TP1 is a good sign for send stage. A 2 or 3 ohm resistor would also be possible for R15 for less heat.
The heatsink I had on the mosfets were probably somewhere around this temp, so I'll assume they're ok. - Keep in mind that depending on pot mounting/wiring you might have to turn the Dwell and trimmer knob down to get reverb once you get a crash working. Pay careful attention to the pot pin numbers on the schematic.
Paid attention to the lug markers for the pots. Installed correct. - Power supply needs a decent amount of clean quiet 12V
Have a rock solid 12v 3A power source
