Guvenator - More Cowbell! No, I mean more Bass
Spiff4565
I assembled a Guvenator recently and over all I am very happy with it.
I'm building another one and rather than PCB mounted pots I'm going to fly leads to the solder lugs.
The reason I'm doing this with the pots is because I want the controls laid out like you would find on a Marshall amp panel, Bass, Mid, Treble, gain and volume. The PCB pots put the order of tone controls Treble, Mid and Bass.
Which brings me to my query. The bass on this pedal is a bit anemic, IMHO. Want I am looking for is essentially a bass boost.is this possible by just changing out passive components or would such a modification require circuit/component wizardry? To be clear I am not looking to change the range of frequencies, I am looking for a way to accentuate the frequencies currently controlled by the Bass control.
I've played any number of amps that employed a bass boost and it is this effect I would like to integrate into the Guvenator.
If there is an existing PCB that sounds similar to the Guvenator that already has this feature or characteristic already baked into the design, please let me know which board to look at.
