Ginsly
After spending the last couple months breadboarding, I have a bunch of projects on the docket - mostly pcbs, but some vero as well.
I'm starting with a Peppermint Fuzz, and I thought I had it sorted out pretty well- I had asked about the PNP/battery situation weeks back and that cleared some things up. I didn't really think about any changes to the footswitch wiring, though.
Can someone confirm how this would be wired up using a 3pdt pcb like the ones below? For one thing, there are two Ground connections in this Vero layout, which I'm not used to - one from the power supply area, and one from the Volume pot. I also won't be using a DC Jack, so I'm not exactly sure how the footswitch board works in that situation. I assume I'd still connect Ground+ and -9v from the vero's top left area to the 3pdt pcb, then connect the battery snap to one of the 3pdt board's DC Jack connections as well as the Input jack's ring (to cut off the battery). The Ground connection coming from the Volume pot would likely be connected to the Input or Output jack's sleeve... correct?
Seems like I could also add an LED and CLR on the fs board like I normally would for a vero build, but would need to swap the orientation if I was connecting (+) from the main board to Ground on the fs pcb and (-) from the main board to 9v on the fs pcb. In that case I'd also connect the black battery lead to 9v on the fs pcb's DC Jack area and connect the red lead to the Input jack's ring. Please let me know if this is all wrong!
I also have PPCB footswitch boards with I-Jack/In/Ground/SW/Out/O-Jack if anyone thinks that makes more sense - in that case I'd just leave the LED off. They're set up differently than the ones below, so I'd love to know how to connect those as well.
Thanks for any input - I'm likely overcomplicating this, but it's just different enough from my normal Vero builds (two grounds, reverse polarity, no DC Jack) that I wanted to double check the correct way to do it!
