DAJE
- Build Rating
- 5.00 star(s)
It's been a while since I posted a build report; I've been having a break from building.
This one was easy and worked first try. No issues for me. I'm a bit unhappy with running the power wires across the board, but that was the best option with the way I wanted to build it.
There's no drill template for this one, and in the end I used the PCB itself as a template, and that worked. I wanted to put the output jack on the front, and this is how I decided to do it. I get the point of wanting top jacks on everything, but in this particular case front is better for me. So, sideways is how I chose to do it and it turned out pretty well. Placement could be improved but it's not bothering me.
I've also included a pic of the current PCB because the layout differs from the one on the product page, mostly in the LED placement.
Anyway, it does what it's supposed to do, sounds pretty good, and I'm happy with it. Not sure which way is "on" with the switch, I think I prefer it with the switch up/left (as shown in pics). EDIT: No, other way sounds better.
