Hell Gazer
Fuzzonaut
This is some Devi Madness rolled into one enclosure, PCB from Fuzzdog.
Basically a Soda Fuzz into a Cone Ripper OD. Both circuits have a switch to let loose some Chaos and/or Noise.
The other switch on the fuzz side flips the orientation of one of the transistors to give you some octave-up.
The second switch on the OD kicks up the gain.
I left out the order switch.
CRAZY WALL OF FUZZ
Yeah! I had an effector 13 sodameiser w chaos and a boost stomper on my board for years. One of my absolute favorites. Is the octave switch just flipping the transistor making it a vintage fuzz master? I made one that does that a while back. So much nasty with so few parts.
Long ago, one of the few times in life that I didn't have to throw my tax return immediately at debt, I wandered into my favorite music shop with no agenda other than ridding myself of money and spent way too much on this. Knowing what's going on inside now I cringe a little but whatever. Just had to have that chaos.
I know in the build doc Fuzz Dog strongly suggests it's not worth including the order switch in this one, but ...
Did you try switching the order up before fixing its position?
I have been trying to figure out what the boost switch does on that SM variant. Do you possibly remember what it actually does in the circuit, or what it sounds like?
It's funny, I took it apart a while back and I don't remember what I found. I only remember the underwhelm.
I just opened it up and took this pic. The switch just connects the blue and black wires coming from J6 and J7 on the pcb. Nothing super obvious to me about what that's actually doing.
I originally thought it must be a transistor flip but having built a few with transistor flippers, the boost has no octave to it like a vintage fuzz master. When comparing with my diy versions honestly the effector13 dimed with boost on kind of sounds like the dimed gain DIY SM while boost off sounds like the DIY SM with gain closer to 2:00.
Interesting! I had thought it might be a flipped transistor as well since someone told me it sounds kind of octave-ish, but yeah doesn’t sound like the octave a VFM produces. I found an old review of the pedal where someone says it gives it “max gain”, I assume just bypasses the intensity potentiometer and just stays stuck at max.. but not sure, though your description sounds like that may be the case! Thanks for taking a look at it!
