Help Me Understand my TC-1
BuddytheReow
Breadboard Baker
Here is a 2n5457. I get that Id is drain current. What does Vg mean? Is this the pinch off voltage?
Vg = [V]oltage measured @ [g]ate.
Vgs = [V]oltage measured between [g]ate and [s)ource.
Vgs-off or pinch = Voltage @ which the DUT shuts off.
Vgs-on or Vgs(TH) = Voltage @ which the DUT shuts on.
Vgs = [V]oltage measured between [g]ate and source.
Tim points out the fundamental issue with JFET testing and the TC-1: It doesn't give Vgs-off, which is the parameter most people are measuring and sorting for.
the R.G. JFET tester is the way to go. I have an old breadboard attached to a 1590DD baseplate that has an R.G. JFET and transistor tester permanently setup. My TC-1 gets used for Si sorting, rough sorting of Ge and as my main passive component tester.
The DCA75 does all that but is overpriced (just my opinion). Like Derek said, a few common components and you have a reliable method. I'd suggest adding a ZIF (they're the bomb for this).
Do you mean this?
I'll do you one better; RTG and headed your way.
