Help needed with Uberdrive
Chase42147
Hey all, my first post here.
I bought an Uberdrive PCB last winter (first ever pedal build) and soldered it all together. I only got a horrid hissing sound, so I set it aside for a year. Today I realized I had forgotten the small jumper wire on the switch, but more importantly; I realized I had hooked the input/output tip contacts to ground. Switched those around, and now I at least get signal through the pedal. The switch works, the tone pot works, and the level pot works. The gain pot, however, does absolutely nothing. Also, I notice a distinct volume drop with the pedal engaged. My questions are
1) I don't have the indicator LED installed, as I inadvertently blocked the holes for it with solder and haven't gotten around to clearing them out. Will that affect anything or is than on its own circuit?
2) I used 2SC1815 transistors as I couldn't find 2SC732s. From what I've read in another thread they should have the same pinout and work well enough. Is that correct? If anyone has any input that would be much appreciated.
Thank you!
Absolutely, here's a few. I know it's sloppy, my soldering skills need some work haha.
The status LED won’t affect anything.
I don’t know about the transistors, sorry.
If you still have issues after reflowing then you probably need to build an audio probe and check the circuit.
It doesn’t look like you used a socket for the op amp (RC4558). You might consider using them in the future to eliminate the risk of overheating the IC while soldering, and to make troubleshooting (if needed) easier.
Ok, great. I'll just leave the LED out for now then.
Yeah, I learned about sockets for IC's after I soldered the IC on lol. I didn't do a lot of research in advance, just kinda jumped in
You're correct on the transistors; the 2SC1815 is a standard substitute and the pinout is the same, so that likely isn't the source of your issue. I would definitely follow the advice on reflowing the solder joints first, as a poor connection around the gain pot or the transistor legs is the most common reason for a volume drop in these builds.
Yep, that was the problem. Good to know for in the future that that is the most common issue.
