dmnCrawler
I am trying to trace the KMA - Tyler The Freq Splitter. I am having trouble figuring out how to determine the SMD capacitor values. There are no markings on the caps and if I am correct they can not be measured in place. I am unsure of the values of C1, C4, C5, C14, C15. I am guessing on the input diode value [1N4148]. And I am very unsure of the schematic. I have spent several days going over it and think I have all the traces correct, but I have only been building for 4 months and my knowledge is limited.
Also the low and high pass jacks do hook up to the wrong filters. I believe they are miss labeled on the PCB. I will fix them in the final version of the schematic. Any help, hints ,tips or other resources to use are greatly appreciated.
If this is the wrong place please let me know the right place.
| C1 | x | R1 | 220-1 | 22R | TH | D1 | x | |||
| C2 | 47 | 16V | R2 | 2204 | 2.2M | D2 | 5mm LED | White Clear | ||
| C3 | 220 | 16V | R3 | 1002 | 10k | D3 | 3mm LED | Yellow Clear | ||
| C4 | x | R4 | 2203 | 220k | D4 | 3mm LED | Yellow Clear | |||
| C5 | x | R5 | 2203 | 220k | ||||||
| C6 | 10 | 16V | R6 | 3902 | 39k | TRIM | 105 | |||
| C7 | 10 | 16V | R7 | 1002 | 10k | TRIM | 105 | |||
| C8 | 47 | 16V | R8 | 1001 | 1k | TRIM | 105 | |||
| C9 | x | R9 | 1001 | 1k | ||||||
| C10 | 10 | 16V | R10 | 2201 | 2.2k | Low Pass | A100K | Dual | ||
| C11 | 10 | 16V | R11 | 3300 | 330R | Level | A100K | |||
| C12 | 10 | 16V | R12 | 1002 | 10k | Mix | B10K | |||
| C13 | 10 | 16V | R13 | 1004 | 1M | High Pass | A100K | Dual | ||
| C14 | x | R14 | 2203 | 220k | ||||||
| C15 | x | R15 | 1002 | 10k | + - | SPDT | ON-ON | |||
| C16 | 10 | 16V | R16 | 2204 | 2.2M | |||||
| C17 | 10 | 16V | R17 | 2204 | 2.2M | Wood | 3PDT | |||
| C18 | 10 | 16V | R18 | 1002 | 10k | Bypass | 3PDT | |||
| R19 | 1002 | 10k | Steel | 3PDT | ||||||
| IC1 | 7660SCPAZ | R20 | 1002 | 10k | ||||||
| IC2 | TL074C | R21 | 1003 | 100k | IN | Stereo Switching | ||||
| IC3 | TL072C | R22 | 1001 | 1K | OUT | Stereo Switching | ||||
| IC4 | TL074C | R23 | 1001 | 1K | LP Send | Stereo Switching | ||||
| R24 | 1001 | 1K | LP Return | Stereo Switching | ||||||
| Enclosure | 1590XX | R25 | 1002 | 10k | HP Send | Stereo Switching | ||||
| R26 | 1004 | 1M | HP Return | Stereo Switching | ||||||
| R27 | 1001 | 1K | ||||||||
| R28 | 1004 | 1M |
