Fretless
Asked Google’s Bard the following prompt:
You are an expert in electronics, specifically high voltage circuits built using 4 layer PCBs for guitar pedals which use tubes running high plate voltages. How would you go about building the high voltage circuit and PCB layout? Also, what would be the overall guidelines or rules of thumb you would use when building the pedals e.g. how would you keep the high voltages from grounding out to the metal enclosure?
… it came back with three possible answers, and this seemed to possibly be the best one:
Building high-voltage guitar pedals with tube circuits on 4-layer PCBs requires expertise and careful attention to safety and isolation. Here's how I would approach it:
High voltage circuit and PCB layout:
Is anyone else using these chat bots to work through this kind of thing, or circuits in general? It seems pretty useful, tho I can’t say I’ve done enough of it to have double checked its answers. The answers it gave to this question seem pretty good! The recommendation to use a variac when first powering up was something I hadn’t thought of before for this kind of thing.
Btw, Bard can analyze circuit schematics, or at least sounds to me like it can haha, tho don’t count me responsible for any hallucinations it might have
- Schematic design: Start with a well-designed schematic that accurately reflects the desired tube circuit topology and operating voltages. Ensure proper biasing and safety measures like bleeder resistors across high-voltage capacitors.
- PCB layout:
- Ground planes: Utilize the 4 layers effectively. Dedicate one layer for a continuous ground plane under the low-voltage circuitry and another for a high-voltage ground plane under the tube circuitry. This creates a physical barrier between the two voltages.
- Component placement: Keep high-voltage components close to the tube and minimize trace runs, especially for high-impedance sections. Use thick traces and wide spacing between high-voltage traces.
- Isolation: Use creepage and clearance distances based on the voltage ratings to prevent arcing between high-voltage components and other traces or pads.
- Bypass capacitors: Place bypass capacitors close to the power pins of ICs and tubes to decouple high-frequency noise.
- Safety first: Always prioritize safety when working with high voltages. Use proper safety equipment and work in a controlled environment.
- Component selection: Choose components rated for the high voltages and currents involved. Capacitors should have voltage ratings at least twice the operating voltage.
- Isolation: Maintain strict isolation between high and low-voltage sections of the circuit. Use isolation transformers for power supplies, optocouplers for signal paths, and double-insulated jacks and switches.
- Grounding: Ground the chassis to the AC ground pin of the power supply. Ensure proper grounding throughout the circuit, including the high-voltage section. Avoid ground loops by using star grounding.
- Shielding: Shield high-voltage sections with metal enclosures to prevent noise emission and accidental contact.
- Testing and commissioning: Use a variac to gradually power up the circuit and carefully monitor voltages and currents. Double-check all connections and component values before applying full voltage.
- Enclosure isolation: Use an insulated enclosure or line the inside with a non-conductive material like Kapton tape.
- Standoffs and insulation: Mount components on insulated standoffs and use insulating washers for hardware.
- Component selection: Choose components with insulated cases or built-in isolation transformers.
- Leakage paths: Identify and eliminate potential leakage paths, such as through component leads or solder joints.
