Mike McLane
Ah, replace the 220K w/ a 250K trimmer!?!? Good idea! Sometimes I'm slow on the uptake. Unfortunately I don't think there's enough real estate on the HV board to insert the Trimmit.
That's a fair point, I was aiming for small footprint, so it's fairly tightly packed.Ah, replace the 220K w/ a 250K trimmer!?!? Good idea! Sometimes I'm slow on the uptake. Unfortunately I don't think there's enough real estate on the HV board to insert the Trimmit.
Yup, that's correct.Got the parts in to modify the trimmer for the HV board. It appears that the "top" side of the 220K (next to the word DAUGHTER) connects to the 5K trimmer. Correct?
Yup, absolutely. I've used it to power as many as 3 without problem.Will this unit power two 12AX7's?
BTW, don't forget the cad file for the PA drill template. Thx.
The input for the L7806 comes from the 9-12V input, not from the HV output. It could potentially get warm depending on how many tubes you're using it for as each tube will present a load of close to 300mA, but L7806 is rated for a 1.5A output.I got this HV PSU from musikding. Maybe a dumb question but doesn't the 7806 need a heatsink? doesn't it heat up considerably especially at 350v? Just checking
Cheers
Sono
The amount of heat generated can be approximated by (Vin - Vout) * Iout. So on a 9V input powering a single tube's heater we have (9-6) * 300 = 900mW. If you're really abusing it running 4 tubes on a 12V input (not recommended) you're looking at (12-6) * 1200 = 7.2W, and that will get very hot.
Replacing the 220K with a 4K7+220K "Teepee" and the 5K trimmer with a 1K makes things MUCH easier to dial in.
Depends on the amp, but potentially. I have one running a 3W amp right now and it's doing great.Do you think this power supply would work in some of rob Robinettes micro amps. I think they make a few watts.
I know you're power amp pedal is similar to a firefly amp which I believe is pretty similar to rob's stuff
I would love to see the schematic on that 3 watt amp, I would love to build me a small tiny amp and run it from your HV power supply.Depends on the amp, but potentially. I have one running a 3W amp right now and it's doing great.
