Hirsute Fuzz vintage silicon
maertz13
A little over a year ago I posed about the germanium Hirstute Fuzz Vintage Deluxe, a shimmery purple affair with a switchable pre-gain and a giant VU meter in the center.
My interest in getting more out of a fuzz face has not ceased. So now I present Hirsute Fuzz Vintage Silicon. Powered by relatively hot vintage Motorola transistors that were pulled from any number of old boards I bought for parts. A pre-gain control, simply labeled “Gain” with the “Fuzz” control set to max with a 1k resistor. “Bias” goes from about 6.5v down to something like 2v at Q2, so anywhere from smooth to broken is available. 4.5v is marked with a dot of paint.
The switch isn’t labeled because I was never sure what to call it. Covering up any more of this very detailed hydro dip would be a crime. The switch isn’t subtle in the least. It goes from the standard 2.2uf in - 10nf out to 22nf in - 1uf out. Not dissimilar to the 3 series fuzz, except I let more bass through the end to compensate. Fuzz to fuzzy distortion, and then you get to add the bias and gain controls to get a wild palette of sounds. The non traditional cap setting can still get really nasty with the bias up a little. It feels very 90’s fuzz.
This is for the person who wants more out of their fuzz face and for anyone who doesn’t like fuzz all that much. A fuzz face on easy mode.
The hydrodip looks great! Did you silkscreen or waterslide over it?
Thank you 😊. It’s waterslide, which gets a little rocky when the surface isn’t flat. So any raised bumps in the paint were very gently sanded. Clear coat, sand, clean, repeat until the surface is relatively flat. Clear waterslide plays a little nicer, especially tossed in the oven on low for a couple minutes.
I was hoping you had some kind of trick...guess I just have to do the hard work I've been avoiding.
Love the Straight-Razor graphic; choice build.
When I next breadboard a FuzzFace I'm going to have to remember to try those switch-values.
Sounds great! Did you try the Cadmium Fuzz (Danelectro Nichols 66)? It has a little bit of everything going on.
Thank you. I haven’t yet, and somehow it has slipped my mind. But I’ll have to get around to that one. Maybe throw in some vintage transistors and see what magic it holds
I honestly don’t think any mojo is needed. It’s a cool circuit as is.
heard. though I will also present this: when you have a tackle box full of mojo transistors, put them in a fuzz :D
It's starting to look like hoarding parts as opposed to collecting them to use at the right time. I'm not a dragon, they aren't treasure.
