You'll get 6dB more gain with that mod, which will be noticeable but not huge. For a bigger increase, you'll need to reduce R5 to increase the max gain, reduce R8 to bring the min gain back in line (if you use that end of the GAIN range) and increase C4 to preserve the voicing. I'd go 3x to 5x smaller on R5 & R8, increase C4 by the same amount that you reduce R5. Use the nearest standard value parts. You can keep the GAIN pot at A500K or go bigger. It all comes down to how much more gain you want.
