How to use a switch to select different resistors
Guybrush
Hi all
I'd like to make R9 on the MK1 Tone Vendor circuit switchable so I can choose from two different values.
Simple question - how do I do this please?
Hopefully it's a simple answer, but a basic diagram would be appreciated if possible.
Thanks.
Here's How I would do it. The blue lines represent the resistor leads, the green, your wire. Using an On/On switch each resistor will be connected to an outside lug and to the middle lug, then a wire from the two outside lugs is each attached to a resistor pad on the PCB. Depending on how the switch is flipped, one of the resistors will be shorted and the other selected.
Or, if you want to get fancy, use an On/Off/On, do a little bit of parallel resistance math (it builds character!), and have three values on tap.
