I have searched the forum and found another person with this issue but it was never resolved.
Finished my build and have no delay sound.It’s working minus the delay. Mix works,volume works but,nothing else makes a change.
Fv1 was pre soldered on board.
Tl072 chips came from tayda.
L78L33 and 24Lc32a came from eBay.
A quick probe on L78L33 pin 1 was 3.?v
Pin 2 was 0v pin 3 was 8.?v
24Lc32a had a reading on the right side pins and nothing on the left pins. I can get a reading if it will help on the right side again.
The only thing is see on other posts is the run a jumper from the right side of R5 to ground and see if there’s some kind of delay effect. This will tell me if the Fv1 is good. I’ll swap out the TL072’s ,L78L33 and ,24LC32a for others I have since I bought more than I needed. Other then that I’m stuck.
Ideas?
Ideas?
