Hydra delay - no signal
tpmc12
Hello everyone,
Finishing off the hydra delay. When I go to test it I’m not getting any signal when the pedal is off or on. The led does turn on.
Below are the pictures with a focus on my off board wiring because that is where I suspect the issue is. The solder joints for the footswitch daughter board are very dull - my first though is to reflow all of those in case one of them is cold.
It’s also my first time using these enclosed jacks.
That crystal oscillator look a little different than the ones I usually see used. The part number looks pretty clear but I couldn’t find it. Is it 32.768 kHz?
Could use a clean with a toothbrush and isopropyl alcohol. I also was wondering with ErikS about that slashy looking line, and make sure there are no solder bridges between pads.
Have you tried each "head" switch? And dimed the knobs? And ensured that the cables are going into the right jacks? I assume you have, but you never do know, especially with myself.
