Hydra FV-1 pin 1 and 28 voltage
Considering the FV-1 runs on +3.3V, a +1.7V DC reading on the in and out pins of the FV-1 seems right - it's ~½ the supply the voltage for that chip for DC offset. Note that C3 (input side) and C8 (output side) block the DC reference from the rest of the +9V supplied sections of the circuit.
Out of curiosity, why the concern of the FV-1 in/out DC voltages?
The volume drop when it is engaged. My reading of the data sheet for the FV-1 made me think that it had to be min of 2.5. But the volume drop could be from somewhere else.
is the volume drop on the dry signal, which doesn’t go through the fv-1?
There are spots where it’d be easy to add boost by subbing a resistor, though it shouldn’t be needed since I believe the volume pot should go past unity volume.
Actually, the FV-1 wasn't working when I last tested it with the guitar. Cold solder on a cap. I will test it tomorrow as I know get signal through the FV-1.
