I bought a bunch of junk
There's a list of most of the audio stuff.
I'm not looking to start an online store or do a bunch of shipping, but if there's something on that list that you need to finish a project, it's not available other places, and you're a forum member whose posts amuse me, there's a decent chance I'd be willing to drop a couple pieces in an envelope for you.
Part TypePartDescriptionQuantity
Transistor2SJ44L2(j44) P-ch JFET300
TransistorJ201N-ch JFET300
TransistorBC263CMetal Can PNP Si30
Transistor2SB737PNP low noise - used in preamp projects:
50
TransistorMPSA14Very high gain NPN - Used in Underminer100
TransistorMPS8599PNP100
Transistor2N3687JFET - Metal can, 4 legs.20
Transistor2n4401NPN50
Transistor2n2222aNPN20
Transistor2SD786NPN Low noise low Rbb 120 - 560 Hfe500
TransistorMPSW56PNP 1 watt100
TransistorBC479PNP20
TransistorZTX796APNP10
TransistorBC261APNP20
TransistorPN5179NPN Low noise100
Transistor2n5401PNP25
Transistor2n5374PNP50
Transistormpsh34NPN Low noise low hfe50
Transistor2n2484NPN metal can8
Transistor2n3856NPN4
Capacitor1nPanasonic ECQ-P or ECQ-V Polypropylene2700
Capacitor1.8nPanasonic ECQ-P or ECQ-V Polypropylene1200
Capacitor2.2nPanasonic ECQ-P or ECQ-V Polypropylene300
Capacitor3.3nPanasonic ECQ-P or ECQ-V Polypropylene1700
Capacitor4.7nPanasonic ECQ-P or ECQ-V Polypropylene600
Capacitor5.6nPanasonic ECQ-P or ECQ-V Polypropylene900
Capacitor6.8nPanasonic ECQ-P or ECQ-V Polypropylene2300
Capacitor8.2nPanasonic ECQ-P or ECQ-V Polypropylene100
Capacitor10nPanasonic ECQ-P or ECQ-V Polypropylene100
Capacitor15nPanasonic ECQ-P or ECQ-V Polypropylene100
Capacitor22nPanasonic ECQ-P or ECQ-V Polypropylene400
Capacitor33nPanasonic ECQ-P or ECQ-V Polypropylene200
Capacitor68nPanasonic ECQ-P or ECQ-V Polypropylene500
Capacitor100nPanasonic ECQ-P or ECQ-V Polypropylene100
Capacitor150nPanasonic ECQ-P or ECQ-V Polypropylene400
Capacitor330nPanasonic ECQ-P or ECQ-V Polypropylene100
Capacitor560nPanasonic ECQ-P or ECQ-V Polypropylene600
Capacitor680nPanasonic ECQ-P or ECQ-V Polypropylene100
Capacitor4.7nPolystyrene400
Op AmpLM310H 17
Op AmpLM301A 25
Op AmpOP27The OP27 precision operational amplifier combines the low offset and drift of the OP07 with both high speed and low noise.66
Op AmpLF441 40
Op AmpTLO82CL 2
Op Amp4082C 4
Power Transistor2SA1144-YPNP10
Power TransistorMJE15031PNP75
Power TransistorD45VH10GPNP75
Power TransistorMJE16002NPN100
Power TransistorK2542N-Ch Mosfet100
Power Transistor2N6474NPN12
Power TransistorGED44VH10NPN15
Power TransistorSC3503NPN30
Power - OtherMUR1540Switch Mode Power Rectifier100
Power - OtherLM7812Positive 12v Regulator100
Power - OtherLM7924Negative 24v Regulator100
Power - OtherMR5040Diode30
Power - OtherMR872RDiode2
OtherULN208LATransistor array9
OtherDM74181NLogic IC4
OtherLM3852Votage Reference Diode40
OtherLF 311HVoltage Comparator10
Other2n2060NPN pair - 6 pin5
OtherICM72171JIProgrammable Up/Down counter10
OtherDBX 8101Mystery DIP8 IC6
OtherDBX 8047Mystery DIP8 IC2
OtherDBX 8043Mystery DIP8 IC1
OtherDBX 8102Mystery DIP8 IC1
Erik S, 2 years from now:
"Hmmmm for this build I still need a 100n cap, a 33n and a 680n ...
1, 2, 3, 4, 5 ... 97, 98, 99... 100 1n caps.
*sigh*
1, 2, 3 ... 98, 99, 100 6n8 caps. Good. 680n
Only need 10 of these in parallel, but with tolerance drift I've still only got 29n7; can throw on another 3n3 — that's 1,423 of the 3n3 caps still in stock... I gotta find a way to use more of these guys up.
Hmmm I need to order more 1590DDs for these Fuzz Face builds...
*sigh*
Feral Feline you SOB!
I don't know much about power transistors, but where would you use a PNP power transistor?
No idea! 🤣
I replaced a few power transistors in a PA amp a while back but I don’t know if they were NPN or PNP.
All that stuff I bought came from a place that makes fancy microphones, and a lot of it made sense for that application - special low power, low noise stuff, but the power transistors are a mystery.
I guess they might have been building gear related to testing mics too?
