If you had to pick one: Fuzz or Distortion?
Fuzz or Distortion as your only dirt pedal?
  • Fuzz
    Votes: 15 55.6%
  • Distortion
    Votes: 12 44.4%
  • Total voters
    27
As a life long big muff fan. Fuzz it is. Lately though I have really been digging the transparent overdrive flavors. Which you can also get from good fuzz by rolling back the volume pot on your guitar.
I guess since I have a Muff and a kliche on my board, depending on who you ask……..I prefer distortion?
I’m seriously considering a Fender Blackface combo. Something like a Super Reverb or a Deluxe Reverb. If I ever want to cranked something, I can use the 5 watt SE amp.
I like the sound of a Princeton reverb a lot. There is something special about the chimey cleans of a blackface. Keep in mind, big muffs will kinda just turn to mush in a mix with a mid scooped amp with a mid scooped pedal.
Mine is a rehoused NYC with a switch for stock tone or mids knob and one for diode lift on the first gain stage. The diode lift is pretty tame
Based on many of the pedals I've used, you can get distortion out of a fuzz pedal but not fuzz out of a distortion. With the right fuzz, you can get a very solid overdrive and then some. Hell, technically speaking, a Rat distortion pedal could be consider a fuzz depending on the setup.
The Rat can low gain overdrive, distortion and a pretty gnarly fuzz sound. And with the drive at noon or lower can do a really good volume knob clean up. Not many distortion pedals can do that
Indeed. And, if you have one with different clipping options, even better. The AionFX Helios that I built can do silicon diodes, LED, and GE ones with a selection switch. Basically gives you a standard Rat, Turbo, and Dirty. I know there’s other pedals that can do the same…just nice to see a DIY with these opotions.
