Informant Drive Error?
JustinW
Hello All!
Just had a question about the Rev 2 Informant Drive..
my silkscreen is different than that on the website/build doc. I've got a 2.2k where R8 is on the current build doc (says 470ohm) and some of the capacitors are different on the sides/middle.
Is this an old or newer revision that has a different build diagram? Should I follow the guide or what's on the PCB?
Thanks,
Justin
I'm curious about this as well. The boards I have been building off of match the build docs, but I'm planning to order some more shortly. I will say, whatever version I have, it sounds dead on like the original unit, and matches the values exactly so far as I can tell.
It appears to be the same as the original revision, it's just a different layout.
Follow the silk screen and it'll be spot on, the build doc appears to be an earlier revision. (Or maybe a newer revisions, either way what's printed on the circuit board is the correct layout.)
Yep, follow what's printed on your PCB.
The circuit hasn't changed, some of the components were moved around and re-routed but everything else is the same.
