Building an informant overdrive. When testing all the pots behave as expected - distortion/volume make the static louder, turning the cut clockwise increases bass, but no guitar signal is getting through. Footswitch and led function, though it does seem louder switching than any professionally built pedal I’ve bought since 2003.
I’m getting continuity on my meter from all of the grounds. I’m also getting continuity through the tip of the input jack wiring to the “in” joint on , because that was my first and only guess based on the symptoms. Reflowed a few solder joints as well. Also stuck/wedged electrical tape on the pots because why not.
Apologies for the sloppy soldering/wiring. Only other pedal I built was a kit during early COVID.
Anyone have any suggestions on what I should try or test?
