Hello everyone! I intended to purchase 6 of the Intelligent relay bypass boards, but accidentally bought 4 of those, and 2 of the intelligent relay DPDT boards.
My goal was to build a pair of "ABC" Y boxes. That is, there would be a single input that could be routed to 1 of 3 different outputs exclusively. My thought was to use the intelligent relay bypass module in "Channel Switching" mode to that when i stepped on any switch, the signal would route to that specific channel and un-route for where it was previously.
In looking at the Intelligent relay module VS the DPDT module, not a whole lot looks different - I see they both have the same values on the silkscreen, with the I/O pads moved to different spots, as well as the power IN pads. both even have CTRL pads.
My question is, would it be fine to use the DPDT pcbs I have for this, and would "Channel switching" mode be present with the pre-programmed ATTINY MCU for them?
Or if not, could I just buy a pair of MCUs meant for the Intelligent relay module?
Thanks.
Thanks.
