Is it just me or is the Simulcast kinda bright?
I got my 2N4033 transistors from Mouser. I really like 'em. What I have done now to tame the brightness is simply put a cap across the base and collector of Q2, the Ge transistor or 2N4033 depending on which one you are using. With the 2N4033 I am using an 820pF or 1nF cap. I haven't decided which I prefer. I find I can get very similar treble response to bypassed with anything from 1n5 to 2n2, but I actually prefer just a tiny treble boost. Call me fickle!
'Although the term Miller effect normally refers to capacitance, any impedance connected between the input and another node exhibiting gain can modify the amplifier input impedance via this effect. These properties of the Miller effect are generalized in the Miller theorem. The Miller capacitance due to parasitic capacitance between the output and input of active devices like transistors and vacuum tubes is a major factor limiting their gain at high frequencies. Miller capacitance was identified in 1920 in triode vacuum tubes by John Milton Miller.'
I assume that this means in plain English that there is interference between successive gain stages in an amplifier circuit which can lower the impedance of the input stage, so adversely affecting the behaviour of the circuit. IOW it's designed to function within a given impedance range and the Miller effect (stray capacitance) messes up the frequency response so that what works on paper in the design doesn't do what it ought to.
That's my story and I'm sticking to it. Perhaps a real circuit guru can confirm my layman's understanding in due course.
I now see that @jhaneyzz mentions putting a cap over the volume pot which indeed should be a Miller cap between collector and base of Q1.
I’ve used a value of 820pf or 1nf and I still keep the tone of the pedal between 0 tot 3 oc depending on the gain switch.
I tried bridging pins C and B of Q1 with a 1nf cap and I can't hear any impact whatsoever.
I am pretty satisfied with a 560pf between pins 1 and 2 of volume however.
And.... of course I skimmed right over the " I'm using a 2n5088 so ignore the transistor orientation." @daeg mentioned and I was testing the wrong legs.
Still crazy subtle to me. on a whim, I grabbed the next cap in my set which was a whopping 4.7nf and tested it, and it actually sounds pretty good to. my ear. not sure what's up with that.
However, since for some forgotten reason I didn't socket ANYTHING on this build, it's going to be easier to just solder a cap on the volume pot and call it a day.
I'll use more foresight when I j build the Duocast mini as soon as they hit the store.
Thanks for everyone's support.
Miller caps are useful, but they lower the input impedance of the stage at high freq and must be applied carefully.
So what then would be the Latvian Orthodox alternative to taming the 6kish spike in the Simulcast (without inserting a lead in a solder lug) <inside joke from another thread>
It may very well be a resonance in the transformer.
You could try removing the transformer and jumpering pins 1 & 6, or experimenting with an R-C damper across R15. Other than the transformer, I don't see anything in the circuit that wold cause a high freq peak. Putting a cap on Q2 is a band-aid.
I'm going to apply the band aid on this one and call it a wrap. at least for now. It's for me so I can always bust it back open if i decide to.
As well, I will definitely be building this again (on the list for the Duocast mini) and will build with sufficient sockets and such this time to allow for a more measured and flexible "finishing process"
I learn a lot of great new things every time and you all are helping with that dramatically.
Join our church to find out!
I have one on the bench. Pretty sure I'll try to sell it if it's as bright as everyone says.
I’ve only ever heard us cork sniffers bring it up. BTW the bleed cap I installed tamed the treble AND the tiny voices in my head telling me to buy a Schecter guitar went away as well… so… bonus!
