BuddytheReow
Moderator
Got a breadboard from Tayda almost a month ago and I’ve been using it, well, let’s say about 5 days a week. Today I’m in the process of putting together a bit larger than normal circuit and testing it in phases to make sure each block works
The booster section is hooked up but little sound is coming out of the collector. It has power going to it. There is signal going to the base too and that checks out. It’s a 2n3904. Swapped that out for a direct replacement but no change.
AND
It then goes into an op amp (4558). I tested voltages and ground is getting almost 9v!!!! Doesn’t seem right. Swapped it out, still 9v. I moved the op amp further down the breadboard and power/grounded it. 9v at input voltage and 0v at ground. So it’s not the chip itself: it’s gotta be the board!!!
would a board die out this quickly!?!?
AND
