nate433
Maybe sort of how the Boss OC-3 can only effect lower strings if you want. Can you do something similar with gain? So maybe i want my higher or lower notes to clip and distort a bit, but not the others?
Just spitballing here.
I've haven't built the pedal yet, but is the Dunwich - Volt Thrower achieving that with the 2 trim pots on the op amp?
