I built this phase 90 amalgamation pedal for a friend of mine a month or so ago. I’ve already had a troubleshooting thread with this pedal, but I got that issue figured out. All was well, the pedal sounded good, so I let my friend take it. Lo and behold, when he got it home and started playing it, the phase was there, he liked the sound of the pedal, BUT! there was a ‘thump’. I told him to try and fiddle with the trimpot, that didn’t help. So, I told him I would fix it for him. When I got it back, it was doing the thump noise, and instead of it just being that noise, it also was like a drastic tremolo. It will go on and off according to the rate of the ‘phase’. I check voltages and such and the biggest problem area is pin 7 of the third op amp. On the multimeter it goes from straight dashes to zero in conjunction with the thump rate. I swapped out the 470k resistor, which didn’t help. I tried a 10uf electro cap in place of the 15uf tantalum and that didn’t help. Tried a different piano, that didn’t help. Does anyone here have any ideas? I’ve provided a couple sound clips and pics of the board, schematic and layout I’ve used. Thank you in advance for any and all help!!!
