mkstewartesq
My issues with the XC Phase are numerous and have me stumped.
Photos of the board attached, along with a schematic. The reason there are no jacks or 3PDT attached is because I have been testing it using the auditorium platform - same for why the LED is just inserted into the board rather than soldered (I plan to wire it off board later).
I’ve checked the values on my components visually – for whatever reason, perhaps they are sold her to the board, I’m getting all kinds of fluctuating readings when trying to test with a multimeter. Continuity seems to be fine between the various points.
The JFETs are a matched quad, purchased from Banzai.
My issues:
Just a bit of additional information if it sparks a thought – as I mentioned in another thread, the area on the trim pot where you can actually get phasing is very very tiny on mine – maybe a millimeter. Everything before that and after is no phasing so I have a very very tiny area in which to attempt to bias.
Any help appreciated – I’m really hoping to be able to save this one because my daughter designed a beautiful enclosure for it that we have already had drilled and printed. So there’s a lot of sentimental value there and because of the very unique layout of this pedal's controls, I’m not gonna be able to find another phaser that’s going to fit in that enclosure.
Thanks for reading my book-length post and for any assistance.
Mike
My issues:
- Ticking in Block mode. This when I can hold off on a bit as it may resolve itself when I get this in an enclosure. But the ticking is odd, almost like a breath – tick followed by a second of silence like an exhale, then the phasing cycle begins again until the next tick.
- Very weak phasing. Furthermore, to my inexperienced ears, the phasing seems irregular and asymmetrical - instead of a steady cycle, it’s more like a heartbeat. My best impression: “wow……....wow-wow….…wow……..wow-wow”.
- I can bias to get Script mode and 4 stage (90 mode) working fairly well (although weak and with a little distortion). But 2 stage (45 mode) is ALWAYS heavily distorted no matter how I bias. As noted, Block mode ticks.
Mike
