- Build Rating
- 3.00 star(s)
Well this was an pretty easy build that I made more complicated. I pressed out the LED spots on the PCB so I had to wire the LED thru the SW and left side of the resistor. Which now I know you can do lol
The reverb at about 1o'clock sounds like a spacey delay. Not sure if that's normal. The pedal has a large noise floor. You can still get some decent sounds with it but I personally don't like this pedal. Not advanced enough to do mods or if they are any. I had the fv-1 done by pedalpcb.
I did the graphic with sticky paper as I had no waterslides with white background available. So they are marks and scratches all over. I added the washers to the switches because I scratched it all up taking it apart over and over lol. I did clear coat it several times but it still scratches easy. I do like the graphic I made however.
