Update: Ok, second mod for today. I was chatting with
@music6000 offline about this pedal too. Or maybe it was online? I'm forgetting hah.
Following
@Chuck D. Bones's recommendation I also replaced R6 (4k7) with a 20k trimpot. I set it at 12k when I put it in and I think I'm going to leave it there.
There's definitely some improvement on the BAT46 side of the toggle, a bit more usable and less overly compressed. But the volume discrepancy is still pretty profound. But I can dial up some nice sounds on both sides of the clipping toggle now.
Best of all, I could do the mod without taking the board out, WOOT!
Very Marshally, I actually think it sounds way more like JCM800 territory than Plexi. The bass heaviness is still there but I think that's probably true of most MIAB's. The tone control is only a treble cut, it doesn't dial out the bass.
But it's definitely a worthwhile mod. Thanks
@Chuck D. Bones and
@music6000!
I know this thread is a few months old but I wanted to comment as I'm currently experimenting with that circuit on the Protoboard (have the PCB on order but I like to lock in my "mods" before I commit)
As you may or may not know, the El Rey Dorado is a Carl Martin Plexitone clone (the small box version). I love the Plexitone circuit but it does have overbearing bass which was my motivation for building my own.
The Panama (Unchained) fixed this by adding a variable high pass filter at the beginning of the circuit (the Damping control), an overly complex solution when you can just swap a cap... IMHO
The Keeley version already does cut more bass than the Plexitone, with a 100n input cap instead of 220n. I feel that's not enough, but I still wouldn't bother with the Panama version unless for some reason you really want flexibility in tightness.
What you can do... just replace C3 with a 68nF or even 47nF. This will rolloff bass frequencies pre-distortion so that the distortion cleans up (makes it more JMP than JTM).
As for the change in volume when changing mode, there's nothing that can be done really, you're switching from diodes that clips at 2V to .2V. I don't find that switch useful (and may actually omit it and jumper the "High" position), to me the LEDs in there are integral part to the Plexitone sound, but maybe Mr Keeley wanted to ensure it wasn't a direct clone by adding something. Going from LEDs to BATs is such an insane jump, plain old Silicon would have made more sense, but I guess some people prefer the clipping nature of BATs.
If the plan is to be able to switch between both easily, then that's not gonna work, it totally changes the gain structure of the pedal. For this to work, one would have to use a DPDT switch and use it to kick in a higher R9 value in "Low" mode. Obviously this wouldn't work with the current PCB.
For the sake of discussion, another difference between the Keeley and original Carl Martin is the Keeley uses a smaller tone cap (39n vs 68n) with a higher value tone pot (B10 instead of B5). I've experimented with the value there and I do prefer the 39n. One other issue I had with the Plexitone is it was a bit lacking in mids through some amps, the smaller cap there moves the rolloff frequency upwards, letting more mids through. Using a larger value pot means it gets darker in the lower range, but in practice I prefer it because now it sounds great at noon while the Plexitone I had the tone always turned down (the Plexitone also uses smaller C2, C5 and C9 caps, at 25p instead of 120p... I changed C9 to 470pF!)
Another change is R3, where the Plexitone uses a 47R which increases the gain range ten-fold! The Plexitone has too much gain as it is (they even released a low gain variant, which sub the 1M pot for a 100k). The 470R sounds good IMHO!
