D dtjacob New member Today at 11:18 AM #1 Can someone help with the right angle pin header between the tube daughter board and the main board??? Can't seem to get it right. Thanks...
V vigilante398 Authorized Vendor Today at 11:24 AM #2 dtjacob said: Can someone help with the right angle pin header between the tube daughter board and the main board??? Can't seem to get it right. Thanks... Click to expand... What do you need help with exactly? The orientation?
D dtjacob New member Today at 11:28 AM #3 Yes the orientation. Not sure how to connect the 2 rows of pins on the main board. Thanks...
V vigilante398 Authorized Vendor Today at 3:45 PM #4 dtjacob said: Yes the orientation. Not sure how to connect the 2 rows of pins on the main board. Thanks... Click to expand... Have you looked at the build instructions? The names and colors of the boards have changed, but the process is the same.
D dtjacob New member Today at 5:47 PM #5 Yes, I read the instructions several times. The link in the instructions sent me to a buffer board of some kind. I believe the link you sent me is the correct one. I won't be able to look at it until tomorrow and I will let you know. Thank you...
