King of Pwn
genXslacker
3.00 star(s)
Behold, the King of Pwn ... simultaneous nods to Mike Piera, Eric Cartman, and Andy Summers. (Sting is a douche bag. His solo music is bad, and you should feel bad if you like it.*)
It's a dual overdrive with a Mesa Grid Slammer circuit feeding a Greer Lightspeed circuit. I didn't bother with an order-flipping switch, because for my ears and go-to rig, Grid-Slammer-first is the only way.
I'm pleased overall with the way it turned out, despite the fact that I'm aware of imperfections. As always, I'd avoid some landmines if I built it again.
For starters, I wouldn't knock the Lightspeed board off of my bench when it was nearly complete. There's evidence of the rough treatment on the left corners of that board. It haunts me.
I really need to figure out how to take closeup photos and have all of the guts be in focus, not just a portion. I've also got more spaghetti in there than I'd like, but I'm leaving it for now.
The boards came from Glory to Ukraine's collection on PCBWay. He's the same guy that Barry at GuitarPCB got most, if not all, of his "Bonus" boards from last year. You don't get much in the way of documentation, but component values are silk screened on the boards, which is always nice. Not so nice is that Glory to Ukraine's resistor symbols are very close to his capacitor symbols, which led to my having to wonder why the Grid Slammer's gain wouldn't exceed unity... and having to desolder two capacitors and replace them with resistors. It's easier to blame the symbols than accept responsibility myself.
Most of my builds lately have been PedalPCB, Aion FX, and MadBean. As such, I'd gotten out of the habit of making sure my default workflow wouldn't block pads later in the process. I had to bend down both middle pots to access the off-board-wiring through holes at the tops of the boards. I really hate doing that, but it turned out fine. And I suppose that's one of the tradeoffs for compact layouts. It was worth it to get them into a BB with plenty of elbow room for switches, LEDs, and jacks.
After stamping and inking the enclosure, I sprayed the top with a matte clearcoat. I hated that and sanded (most of) it off. I might try gloss or semi-gloss in the future, but I'm not letting raw aluminum in the same room as matte clearcoat ever again.
*Mostly kidding, you do you.
Oh, I share your thoughts here - having seen interviews with Andy and Stuart (as well as Sting), I have to say that there was plenty of pretentiousness to go around in the Police, but Andy seems the most likable.
Somehow you make that enclosure look spacious. Nice look.
(btw, what do you use for your pics? if you have a newer iPhone you can use alt software that captures the raw at full resolution (i.e. 6048x8064). I shooting this image resolution from further away (so focal plane is deeper / distances are more uniform) and cropping.
It's always nice to find a cultured person on the Internet.
Thanks. That guy's small boards certainly played the biggest part in that.
A latish-model Google Pixel. I don't have much knowledge of photography or optics, but I have wondered if a wide-angle clip-on lens would help.
I put a pedal pic in GIMP the other day and used the lens-distortion tool to make some corrections. That helped a little, but my OCD has limits. That process is way too labor-intensive for me.
Back in the early 90's Sting cancelled a concert for no good reason in my area. All the local radio stations started calling him "Stink" because of it. The name has stuck. My wife and I know who we're talking about when we say "Stink" or refer to "Stink". It's pretty funny actually....... :ROFLMAO:
And while I don't particularly like his solo music, Hiram Bullock's solo on "Stink's" version of Little Wing is absolutely killer and worth listening to.
💯 shooting further away then cropping is the way to go for sure. I have a recent iPhone pro and don’t even need to go the raw route this way. Though I’d like to explore some other software to tone down the heavy handed processing.
If your pixel is anything like the iPhone, getting further away should give you two main advantages:
1. It will probably switch to the “main” lens/sensor, which, at least in my iPhone 16, is much higher resolution than the wide sensor it uses when it thinks you want macro photos.
2. Gives you some natural compression. Not the kind of compression you get from a bluesbreaker, but perspective compression. Essentially the further you get from your pedal, the closer the components get to one another *relative* to their distance from your lens. Apologies to any optics experts in the room for the rough explanation.
And now my wife and I shall call him Stink.
I have a 14 Pro and use the app ProCam, which lets you avoid a lot of processing. I barely use it's features, but shooting full resolution at 1x gives me far better detail than 2x on the Camera app.
