Tremster
I built the Kittywampus (Mr. Black Thunderclaw) that whines like crazy.
The pedal calls for an LT1054 charge pump, I used an LT1054CP (isn't that the only 1054 you can get?).
If I put in an ICL7660SCPAZ the pedal is quiet and works fine.
It's weird that the "correct" IC doesn't work and the other one does. Should I just leave the 7660 in? Get a different 1054?
Can I link or cut some pins on the 1054 to make it work?
Anything else to consider if I leave the 7660?
Thank you.
Thank you.
