Kliche electrolytic capacitor arrangement in build docs
jadedbat
Hello PedalPCB,
Firstly, thank you for an awesome service and playing a key role in getting me hooked on DIY pedal building :)
I've noticed something regarding the build docs for the Kliche that may need to be updated. When I compare the placement of the electrolytic capacitors which direction they go according to the circuit board vs. what the actual Kliche.pdf states is different -- at least in the board I have (PCB003). They wisely all point the same direction (negative facing south), but the docs have them called out differently.
As I wait for some GE diodes so I can test, I'm now uncertain about arrangement. I went with what the circuit board suggested. Any ideas?
Joe
Yes, follow the markings on your PCB.
I'll get the image in the build doc updated later today.
