in these T/C-x jobbies that's got convenient self-piercing technology in it!
Nah. The cold solder blobs are pretty blunt.in these T/C-x jobbies that's got convenient self-piercing technology in it!
I didn't measure mine. Just mental estimation off memory/not caring and picking a ridiculous capscity. One could easily deleter the jst or solder in a jst cable and wrap it around from the front of the PCB.Too big! 14mm thick that guy. Probably end up interfering with the JST XH connector too: 74's about 9mm longer than I'd go.
I meant if some king spanner went in there, installed Sr Chungus, and put it right over the connector plug and transformerNah. The cold solder blobs are pretty blunt.
Believe it or not, the TC-1 is far and away the better tester.I'm on my third TC-, the one died, another came DOA. The third one is working well. These feel cheap, they only cost about $17.
I just got an LCR-P1. While these are built better, I they don't seem to show leakage for Ge transistors like the TC-1.
Just bumping this in case anyone - new or seasoned - has considered the LCR-P1 over something like the TC-1.
Don't!
After numerous firmware updates, the device STILL does not correctly determine the pinout for NPN transistors. It may have other bugs too.
Try this with the LCR: insert an NPN transistor. Test it and see what the pinout is. Now take it out and flip it. Test again. It’ll likely be the same pinout. They’re aware and evidently unable to fix this bug after several months- which is weird since the TC-1 has no such issue.
The LCR-P1 has also given me wildly incorrect capacitor readings. It’s unreliable. Honestly, I’d return it.
