pbrommer
Usually I can troubleshoot okay-ish, and have a Flange with No Name board working, but this one is stumping me. I’ve ran an audio probe through the circuit: step 1, passes through with bypass off. step 2, I lose audio in the circuit.
My goal was to make sure the audio portion worked before tackling the trimpot calibration. I’ve zoomed in on the trouble spot
The problem seems to be that I have audio on the upper part of R22, but then nothing on the other side. I pulled it, checked it (22k — correct) and put a 20k in (what I had on hand). Still has the same issues. Q1 measured all at 7.05V, but then when I removed it, the Gate voltage dropped to 4.5ish.
Ideas? I did scour Madbean and other forums, but no dice. Thanks
PS learned that you can’t use a mn3207 with 15V - it makes mn3207 sad.
Link to file to look at schematic, etc: Flintlock
