So asking here as it's full of people with knowledge.... and this is a problem I had 3 years ago and sold the pedal... then bought it back....
And it all sounds grand...
And then the main lights at church got turned on, lots of LED spot light....
and
BZZZZZZZZZZZZ
Somehow the lights, or the EMI muck from them makes a buzz from the pedals than then goes into the PA...
So turning off the Colourbox killed the buzz - which I think makes it into a passive DI box only using one transformer.
So using a HX stomp into the PA is fine with the lights on
And using a colourbox into the PA is fine with the lights on
Using both is fine
Until the lights go on?!
- I have a pedal board.
- It sounds good.
- Power comes from a Cioks DC7 - with isolated supplies, included grounds isolated from one another. The DC7 plugs into a 3 pin plug giving it standard mains power.
- Second from last in my chain is a HX stomp. Powered from two outputs on the DC7
- The Jack out of that pedal can do a balanced signal on a TRS, but I use a TS which goes to...
- The input of a JHS colourbox v2. It has input and output transformers and a preamp, I presume using a charge pump to give I am using the XLR out on it to...
- The Allen and Heath PA. The stage bits and speakers plugged onto the same mains sockets as the DC7...
and
BZZZZZZZZZZZZ
Using both is fine
