thesoundofjusticefx
With the toggle switch in the down position, R101 and C101 short to ground. Up and middle position work fine. I removed the toggle switch to see if that was causing the problem but I get the exact same issue shorting the pads on the pcb. I am so confused because looking at the schematic there is no reason. I put a meter over all the resistors and they show the correct values. I even get continuity between the resistors and capacitors between vRef, toggle switch and resistors in that let of the circuit. I’ve already reckoned the solder and checked for solder shirts just in case. Any ideas? This is the newest revision pcb342. Thanks.
