Nope. That’s too small. I have a bunch of those.Assuming it’s the same as the other PPCB faceplates, I think you want this duder:
3mm LED Lampshade Protector Clear Plastic Clip
Get It Fast - Same Day Shippingwww.taydaelectronics.com
There’s also other colors besides clear in that size.
It's probably the same hole size for the electrovibe faceplate as well..... I use basically the same as jcpst suggested but the 5mm version... you have to open up the faceplate hole slightly for the 5mm version.... i just do it with a drill bit by hand with my oversized/undersized drill bit set..Couldn’t find the answer on the forum and the build reports I found all raw dogged the LED. I tried fitting different LED bezels I have but none of them would fit. Well, one did but the shaft is too long and would short the LED pads on the board. So, @Robert which bezel fits the faceplate?
Eh, I was looking for an excuse for more pink bags…Yep. This should be it:
5mm LED Lampshade Protector Clear Plastic Clip
I just pressed one into a faceplate without having to enlarge the hole, but it's definitely a tight fit. It's not going to fall out.
I have some here if I'm already shipping you anything by any chance.
