eh là bas ma
Hello,
I am currently building the Low Tide, from a musikding kit.
First, i should mention that i have been confused with 2 unnamed smd transistors. probably the SK208 and the J201. No labels, i can't tell them apart.
I tried both at both locations, and chose the setting with the most noticeable volume boost, when toggling the internal DPDT.
The other smd transistor works too if i swap them, but the volume boost is a bit weak.
Edit 2 : I could read 62P on one of them, it's the J201, problem solved.
Everything looks fine so far, all controls are responding, but I can't keep the circuit's modulation on, unless i keep turning the depth control like a "manual" mode, or if Slew control is set in the first quarter of rotation. I do have a beautiful chorusing effect, when i do the manual mode, turning the depth control back and forth.
With Slew fully CCW, it sounds like the randomization thing is working, the modulation's curves are kind of irregular and weird.
On most settings, it sounds like a flanger stuck on "Filter Matrix", with a low-pass filter.
It's not very far from the utube demo though... but on my build, when Slew is near the middle of the rotation and above, the modulation disappears.
official demo from the original unit :
www.youtube.com/watch?v=sYWuTmgVU9k
On the other hand it doesn't behave like MichaelW's build, with all controls at 12' :
BBD trimmer is set near the end of the rotation, CW. at both ends there are distorted aeras. I notice a slight volume boost when turning the trimmer CW. I set it where it was the loudest, without being distorded.
Gate trimmer is also set somewhere towards the end of the rotation, CW. Around the middle of the rotation, increasing the lowpass i guess, i hear some sort of bass popping noises on the attack of the notes. I set it somehwere just before this happens.
In short, the modulation seems to be activated only when Slew is set in the first quarter of rotation. Other than that, i can get a nice enveloppe filter effect, once Gate trimmer and Gate control are set to do so.
It isn't chorusing, it isn't flanging, it does an enveloppe filter effect, and a weird and beautiful vibrato thing when Slew is fully CW.
I guess there's an issue somewhere...
What should I do ?
All suggestions and observations are welcome !
Edit : Hopefully, it's only a calibration matter.
Looks like I managed to get some sort of modulation with Slew at the middle of its rotation, by tweaking the trimmers. But nothing as beautiful as MichaelW's exemple yet.
I am using a loop station to send a signal into the circuit, while trying to calibrate it. It's a recorded loop with a few notes, played with a guitar equiped with active pick-ups, guitar's volume set at the middle of rotation. PAD switch is off, Boost is on.
Any tips about the calibration process ?
Edit 3 : I can't find the chorusing spot on the BBD trimmer. Here are some readings :
All controls at 12'.
IC 1 LM78L05
9.11V
0V
5.08V
IC2 randomizer
1= 4.75 8= 5.08
2= 4.00 7= 5.06
3= 5.06 6= 5.08
4=0V 5= oscillating from 1.00V to 4.00V
IC3 LM13700
1= 1.134 16= 1.134
2= 5.37 15= 5.37
3= 4.81 14= 4.80
4= 4.81 13= 4.81
5=5.73 12= 5.78
6= 0V 11= 9.11
7= 5.74 10= 5.78
8= 4.76 9= 4.69
IC4 LM258P
1= 1.222 8= 9.11
2= 2.5 7= 2.8
3= 2.5 6= 2.8
4= 0V 5= 2.8
IC5 MCP602
1= 4.0V 8= 5.08
2= 4.0 7= 3.9
3= 3.5 6= 3.9
4= 4.0 5= 4.4
IC6 CD4046
1= 7.7 mV 16= 5.08
2= 2.4 15= 1.2
3= 2.4 14= 5.8
4=2.4 13= 7.8mV
5= 0V 12= 2.7
6= 0.7V 11= 2.2
7= 0.7V 10=3.1
8=0V 9= 3.7
IC7 V3207
1=0V 8= 3.4
2= 2.4 7= 3.4
3= 2.8 6= 2.4
4= 4.75 5= 5.08
What should I do ?
IC 1 LM78L05
9.11V
0V
5.08V
IC2 randomizer
1= 4.75 8= 5.08
2= 4.00 7= 5.06
3= 5.06 6= 5.08
IC3 LM13700
1= 1.134 16= 1.134
2= 5.37 15= 5.37
3= 4.81 14= 4.80
4= 4.81 13= 4.81
5=5.73 12= 5.78
6= 0V 11= 9.11
7= 5.74 10= 5.78
8= 4.76 9= 4.69
IC4 LM258P
1= 1.222 8= 9.11
2= 2.5 7= 2.8
3= 2.5 6= 2.8
4= 0V 5= 2.8
IC5 MCP602
1= 4.0V 8= 5.08
2= 4.0 7= 3.9
3= 3.5 6= 3.9
4= 4.0 5= 4.4
IC6 CD4046
1= 7.7 mV 16= 5.08
2= 2.4 15= 1.2
3= 2.4 14= 5.8
4=2.4 13= 7.8mV
5= 0V 12= 2.7
6= 0.7V 11= 2.2
7= 0.7V 10=3.1
8=0V 9= 3.7
IC7 V3207
1=0V 8= 3.4
2= 2.4 7= 3.4
3= 2.8 6= 2.4
4= 4.75 5= 5.08
